Repair abs break module
How do i repair Anti break unit repair
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
@testemail what makes you think that you have an issue with your ABS unit? Have you got your vehicle scanned? Any error codes? What are the issues with you brakes? What exact year is your 300?
por Compartilhar
In addition to oldturkey03's question, if the abs indicator turned on and remained on, there's an error code but decoded by readers/scantools Autozone, Advanced Auto, transmission, collision and repair shops have. Not generic low cost readers. If the abs indicator cycles on and off with other indicators when turning on ignition, abs is operating correctly (power on self tests including all wiring to wheel speed sensors). Abs errors are usually C type codes.
por Compartilhar
Adicionar um comentário
