Ir para o conteúdo principal
Modelo Mid 2012, A1278 / processador i5 de 2,5 GHz ou i7 de 2,9 GHz.
Fan Spin - No Boot - No Display
2012 A1278 Model on the bench.
It turns on, fan spins, but that is it nothing else happens.The sleep light is on.
I have tried, removing RAM, Swapping RAM, Without the KB connected, Without a display, different HDD / SSD, Different working HDD cable, Reset SMC, PRAM etc..... Board looks clean, no water damage evident. Owner siad it just wouldn't start anymore. It does charge the battery though.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
What's good Livfe? This sounds like the CPU might not be executing?
It could also be a corrupted Bios.
For the CPU:
Check:
  • PPBUS_G3H (~12.6V)
  • PP3V42_G3H
  • PP3V3_S5
  • PP5V_S5
  • PP3V3_S0 (after power-on)
  • CPU core voltage (VCORE)
If VCORE never appears, the CPU isn't being enabled.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks, we will look into this and update with any findings :)
por
Adicionar a sua resposta
livfe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 52
