Ir para o conteúdo principal
Um laptop de 15,6 polegadas identificado pelo número do modelo: BoB-Wai9
No Boot Device After Turning On the Secure Boot
Huawei MateBook D 15
I tried to enable Secure Boot.I got the error No Boot Device, I can only go into windows when I disable it. But I need the Secure Boot enabled so I can play Valorant.
When the Secure boot is enabled Bios does see the SSD
Is it a problem with the Windows UEFI do I need to format the PC.
Güncelle (07/21/26)
It does show the asterisk. But I dont have the Bios setting for CSM/Legacy support does not exist in BIOS. I tried to reset the BIOS, nothing changed What should I do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hello, it could be a couple of things I can think of, to help find out the cause, boot into Windows with Secure Boot off, open a command window cmd ctrl-shift-enter or just open admin cmd,
type:
diskpart , hit enter
type:
lis dis , hit enter (short for list disk)
check the output, find your disk - in the GPT column for your drive is there an asterisk? If not, then that is why. You would need to investigate mbr2gpt conversion, which can be... a little more tricky, or not!
If your disk is GPT format already, then the culprit could be in BIOS settings, look for Legacy/CSM Support type options, usually they are off when Secure Boot is turned on, but it really depends on the BIOS... (search up your motherboard and BIOS version + secure boot may help?)
Esta resposta foi útil?
Pontuação 0
2 comentários:
por
Secure boot in Windows needs the TPM enabled, the GPT format, and a supported CPU. Not familiar with Huawei laptops/BIOS, if no legacy options or CSM then that is not the problem.
The default/reset turns Secure Boot on - No boot device found could point to corrupted EFI, so you could try recreating boot files:
You will need to boot into your windows installer USB, go to Advanced, fire up command prompt and go through the process of recreating your EFI boot files.
eg
diskpart
lis dis (from the list identify your windows drive, usually disk 0)
sel dis 0
lis par
lis vol (find the FAT32 formatted partition + your windows partition, note the drive letter/s, if the boot part doesn't have a drive letter, give it one via:
sel par <number of the FAT32 partition>
assign letter=s (or other unused letter)
exit
(now recreate the boot files with bcdboot:
bcdboot C:\Windows /s s: /f UEFI
(assuming C: and S: but could be different)
If msg says successful, exit, restart. If not, boot partition needs recreating, or other issue
por
Adicionar a sua resposta
Eren Günaydın será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 56
Ao todo: 66
