How do you get a replacement battery same size
How to get a replacement battery
Esta é uma boa pergunta?
If your battery pack is made up of three 12v batteries, you can buy them from Home Depot or online from many battery distributors. The basic 12v sealed AGM battery is rated for 7 amp hour. There are many applications for this battery; home alarm backup power, Verizon Fios battery backup for Verizon phone line coupled to its fiber optic system, hobby power for radio control engine starters before electric power took over, etc. Examine labeling on your battery pack for specs. AGM is more expensive than conventional sealed gel cell batteries and probably hold up better to high current demands of electric lawn mowers.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 31
Ao todo: 78
2 comentários
The part number is 90550289SV but I don't kno where you would buy it.
por Albert Einstein
@alberteinst6187 According to parts diagrams from this link, https://www.ereplacementparts.com/models..., the drawing shows three batteries. My guess is if you measure each battery for H x L x W, the dimensions should match available lead acid batteries I showed, below. While the battery pack is discontinued, it's just a matter of determining if a) a three pack of original batteries make up a 36vdc battery pack, are 2) batteries with the same dimensions that are available anywhere online, Home Depot, Lowes, Target, etc, then 3) buying three and transferring the wire connectors from the original pack to the new ones. Wired in series; positive terminal of battery-1 to negative of battery-2, positive of battery-2 to negative of battery-3. This leaves the negative of battery-1 and positive of battery-3 to connect to the mower.
por F Dryer
