Ir para o conteúdo principal
Guias de reparo e informações de desmontagem para o MacBook Pro de 16" lançado em novembro de 2019. Modelo A2141, EMC 3347.
Leftmost 512 pixels not displaying
I got this machine cheapish as the original display was smashed. The full image could be seen though. I had a spare here and it works fine except the leftmost 512 pixels which is very telling. That’s exactly 1/6 of the panel. There’s no physical damage to the display but I have noticed the lugs holding the metal covers over the ribbons down on the tcon have failed only on the innermost lugs. I suspect it’s been badly flexed at some point. My question is, could there be a tcon issue here? It feels more like that than a damaged lcd or flex gate. Never seen a flex gate lcd like this.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The LCD panels ribbon cables is likely the issue, either they are damaged or the connection to the connection to the T-CON board. Does it look like someone tried popping off the LCD panel? Can you post some pics of the areas suspected of damage?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Joel Whybrow será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 20
Ao todo: 81
