How to remove pink lines from screen
My laptop screen has some pink horizontal lines at the bottom. How can I fix this?
Esta é uma boa pergunta?
Ouch! Lines tend to be a damaged LCD panel. You'll likely need a new display to fix it. To be sure connect your laptop to an external display if the image there is the same with pink lines that you have a logic board issue otherwise you've proved the disp,ay is damaged.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 64
