Ir para o conteúdo principal
O novo formato da Apple para a linha 14 apresenta uma tela OLED de 6,7 polegadas — assim como o Pro Max —, mas traz os mesmos recursos do iPhone 14, com um sistema de câmera dupla e o chip A15 Bionic com GPU de 5 núcleos.
Logic board replacement without screen removal?
Is it possible to replace the logic board without removing the screen to access the press connectors from the front. ( can I just press the logic board down onto the screen connectors from the inside?) I don’t want to risk breaking the screen if I can get away without removing it
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi Gordon,
Yes, it is possible; actually the iPhone 14 plus is designed so the motherboard comes out from the back, not the front. The repair guide I found for it doesn't require removing the display for a logic board replacement, so you don't have to worry about damaging the screen at all.
Manuals / Apple iPhone 14 Plus / Motherboard - Nobody Calls Me Chicken
The site is in Spanish but does have an English language option, but it's somewhat incomplete so it's best to use it with a browser like Chrome that will do translation. Otherwise their guides are complete and well written and will get you through the repair with no problem.
Good luck, and let us know how it turns out! And while you're at it, take lots of pictures and once you're done you can use them to add a motherboard guide to iFixit's collection. It's easy, fun, and will have the appreciation of the repair community.
Create a new Guide - iFixit
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Gordon Jerome será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 31
Ao todo: 120
