ECAM 450.55 G ELETTA EXPLORE replace Standby-Button
Hi folks,
Does anyone have an idea how I can disassemble the top section of the Eletta Explore?
I need to replace the standby button.
Thanx
Peter
Esta é uma boa pergunta?
Hi folks,
Thanx
Peter
@peterschauer I found a (very long) video for you.
Esta resposta foi útil?
Thanx so far, but I've found that video already. Here the machine will be disassembled, except the top section which contains the standby button.
Kind regards
Peter
Hi Folks,
I solved the problem meanwhile.
I fixed the four central snap-ins with cable ties and was then able to release the latches along the edge using a little(!) force.
Thanx for your support
@peterschauer Congratulations! That's great news. Thanks for the feedback.
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 136
2 comentários
@peterschauer let's see if our coffee maker Guru @vauweh has a solution for you.
por oldturkey03
Kind regards
Peter
por Peter Schauer
