Ir para o conteúdo principal
Informações de reparo e desmontagem para os fones circum-auriculares sem fio com cancelamento de ruído Sony WH-1000XM3.
pulsating red light while charging
The nearest light to the USB connector pulses or flashes during attempt to charge.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Some fast chargers are not compatible with the Sony WH-1000XM3.
Try plugging them in through a wall adapter with lower power, less than 40W is recommended.
Some people on the internet also suggest "hitting the right ear with your hand a few times." I don't know why that would help but why not!
If all else fails, it could be a software glitch - a factory reset might help. You would hold the power and NC/Ambient buttons together for 10 seconds as per Sony's article which I recommend you read through.
Let me know if it works!
Best,
Isaiah
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
mikegmo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 31
Ao todo: 146
