Ir para o conteúdo principal
Repair and support information for HP Laptops, designed for home and home office use.
1040 Perguntas Visualizar todos
How do I replace the base enclosure of my computer?
So a plastic piece came off of my base enclosure on my hp-dv7-6199US. I have ordered the correct part for it, but I am worried about the teardown procedure I found here: http://h10025.www1.hp.com/ewfrf/wc/manua....
I was wondering if anyone had any advice while I am doing this teardown as an amateur? Please help me so I don't have to shell out over $200 USD to get this fixed!
The part I ordered was this one: http://www.fixya.com/support/p4525860-hp...
Any ideas, folks?!
Thanks in advance!
Kind regards,
Ant
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Anthony, that is a pretty good guide, but just like any written manual, make sure you familiarize yourself with it first. Read through it a couple of times before you disassemble your computer. Make sure you have a clean workplace, good light, and all the tools that are required. Take your time and have fun. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you for the kind words of encouragement.
por
Adicionar a sua resposta
Anthony será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,357
