Ir para o conteúdo principal
My F1 fuse keeps blowing.
The F1 fuse on my SNES keeps getting tripped. As soon as I plug in power the fuse blows. I’ve checked the voltage regulator and It seems good. I can’t find any other glaring issues but clearly there’s a short somewhere. Any help would be appreciated!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
To check the voltage regulator u need voltage that u wouldn't have if the fuse is blown. Fuses blow because of a high current drain over their rating. The first thing to check would be the power capacitors since that is mostly visual, leakage and/or expansion. However, the most common cause is bad diodes in the power supply. So, put your DVM in diode mode and check all the diodes and large 3 terminal devices. After that it would be a shorted component on one of the power rails, which might be detectable using a DVM with a very low resistance range.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
JThorn90 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 55
