Ir para o conteúdo principal
Lançado em novembro de 1998, identificado pelo número de modelo HKT-3020.
What is going on here?
Hi, I recently install the retro gem for my Dreamcast and when I boot the system it doesn't show the boot animation for the system only when its completed I went to debug menu and have hearts on all my installs as well as updated the firmware. I tried this on two TVs and it does the same thing. I have a Gamecube with a plug-in mini-HD to HD and it does something similar I used the same cable from that.
Esta é uma boa pergunta?
Pontuação 0
8 comentários
Hi!
Is it possible to upload some pictures regarding the issue you are facing?
Adicionar imagens a uma pergunta já existente
Thank you.
por
Can I upload video? pictures won't help
por
Yes you can!
Using Media
Thank you
por
Hi, I upload the videos in the first video it's the gamecube with the hdmi plug-in, the second one is the gamecube with S-video, and the third one is the dreamcast with the mini-HD to HD. I used the mini-HD to HD from the plug-in I couldn't get the av footage for the dreamcast cause I think I messed something up ....again, but it does the same thing as the gamecube plug-in. I hope its just the mini-HD to HD cable that's causing this. It's the basic edition of pixelfx mod
por
Okay, replacing the cable you can try indeed. It does not really look like a hardware issue in the first 2 pictures. More firmware related. Which firmware has been installed? Thanks!
por
Exibir mais 3 comentários
Adicionar um comentário
1 resposta
Solução escolhida
@dan0 Hi, I went on the retro gem discord and I was told that the delay in video is normal because the retro gem is booting.
Esta resposta foi útil?
Pontuação 0
3 comentários:
Alright. Then it is normal behaviour. Thanks for sharing!
por
Sorry for the delay thank you
por
No problem at all! Have a great day :)!
por
Adicionar a sua resposta
Christopher D será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 36
Ao todo: 215
