Ir para o conteúdo principal
Número do modelo A1707. Lançado em junho de 2017, este MacBook Pro possui processadores Kaby Lake com até Intel Core i7 quad-core de 2,8 GHz com Turbo Boost de até 3,8 GHz.
Forget mac Password and icloud email
So my macbook screen broken a long time ago, im not use it for decade but when i want to replace the screen im forget the passcode and icloud email
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
1 - Is the Apple account being used on another device that you have that is still logged in? You can reset the PW etc using that other device if so & or remove the MacBook from linked devices.
2 - TRY contacting Apple to see if they will give you any clue as to which email address was used for the Apple account.
3 - Your only real other option would be to reset the device (Losing all the files) with internet recovery (Power Up + R) and follow the instructions. But, then the MacBook will likely be locked to the Apple account (Until it is removed or signed out) & POSSIBLY upon resetting it 'Might' prompt fo enter the PW..... Especially if is is firmware locked. One of these videos might help.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Gerry arisandi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 75
