How to fix broken wire
How to fix my broken wire it only works when it is bent
Esta é uma boa pergunta?
Not much you can do to fix the wires, you really need to replace the full cable assembly. Depending on the device the manufacturer might offer a replacement cable or you might be able to splice in a replacement cable using a standard USB-C cable that meets the needed wiring requirements.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 54
Ao todo: 263
