Ac blowing hot air
Why is my ac showing high pressure on the low pressure side. I changed the orfice Tube filter and the dryer filter. I also changed the compressor
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
What was the reason for replacing parts? During repairs, were new O-rings lubed before connections made? Did you use a vacuum pump and gauges to completely evacuate this repair and when pump was turned off, checked for vacuum holding without air getting back in to the system as indication of restoring a factory seal before refilling with refrigerant and oil? Vehicle ac repairs are unforgiving of mistakes and short cuts.
por
Adicionar um comentário
