Ir para o conteúdo principal
Guias de reparo, desmontagem e informações sobre resolução de problemas para a quinta geração do controle Sony PlayStation 5 DualSense. Identificado pelo número do modelo CFI-ZCT1W e pelo modelo da placa-mãe BDM-050.
R1 button not working
Ok so I have replaced the ribbon film as well as the rubber bumpers as well as the R1 button itself as well as clean all contacts and everything works on the controller but the R1 button. What would cause this single button to not work with all the items that I replaced what could cause this problem ??
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Ok so I think my next step is buying a digital microscope because after calibration of the sticks the only thing not working is that r1 button….
I’m saying that the person that replaced the sticks probably was a novice or beginner as the sticks were not calibrated and I’m pretty sure there is damage to the mother board that I just can’t see cause my eyes can’t focus that small anymore
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
Since you have replaced all the parts regarding the button, it’s most likely something else.
How are the traces on the motherboard? Still good?
Are you sure that you used the correct membrane?
Esta resposta foi útil?
Pontuação 2
8 comentários:
Yes I made sure all parts were for the Bdm 050R it has to be a mother board issue from too much heat is my guess now it’s to try and find it lol
It was not me that replaced the sticks so I know it’s not something I did but I’m pretty sure the person who replaced the sticks did as he also did not calibrate the sticks
por Compartilhar
Looks like it unfortunately… the only thing left now, is the motherboard. Sorry for the bad news..
por Compartilhar
Does anyone have a picture of the trace paths on the mother board so when my microscope comes in I can try and find the break??
por Compartilhar
I’m sorry, I do not have a picture :(. But I would check where the membrane circuit is connecting to on the motherboard. Check the traces from there!
por Compartilhar
Ok as soon as my digital microscope gets here I’ll just check the entire board I’m sure I’ll find the break and be able to repair it if not this controller will be parts only lol sad because it’s like new and everything works but that dang one button lol
por Compartilhar
Exibir mais 3 comentários
Adicionar a sua resposta
innisd será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 29
Últimos 30 dias: 108
Ao todo: 404
