Switch lite screen misaligned
Hi, my switch lite screen is misaligned and looks wonky. How would I go about fixing it? Is it possible to do without opening?
Esta é uma boa pergunta?
Hi!
Thank you for the pictures!
As in the last photo it's indeed slightly misaligned.
Since when did this happen?
Anyway, the only way to fix this, is to open it up and check how the screen is sitting in there. If possible, try to align it manually (carefully).
Those screens are incredible fragile, so be careful all the times.
In the worst case, a screen replacement is needed, but I don't think this will be the case.
Guide for how to get there: Substituição do LCD do Nintendo Switch Lite
Please let us know how it goes!
Esta resposta foi útil?
It is new, I noticed it after I set it up, problem is it's the japanese version so Nintendo won't accept the warranty in UK. I will try to get used to it for now as I know it isn't the worst but if not I will try the repair myself. Thanks for the responses.
Ah, definitely a factory fault here. Whenever you go back to Japan, you can get it swapped for a new one. I agree, whenever it's completely new, I won't repair it as well. Have a great day!
Últimas 24 horas: 1
Últimos 7 dias: 27
Últimos 30 dias: 80
Ao todo: 308
2 comentários
Hi!
Can you share some pictures with us, as how it looks like? This will help us to identify the issue.
Adicionar imagens a uma pergunta já existente
Most likely it's just the screen and yes you most likely do need to open it up.
But we cannot say anything for sure without the photos.
Thank you!
por koppie007 Compartilhar
Images added
por Awais Ali Compartilhar
