Ir para o conteúdo principal
A terceira revisão do clássico Controle Sem Fio Xbox foi lançada em novembro de 2020, acompanhando o Xbox Series X e Series S. Este controle é compatível com versões anteriores dos consoles Xbox One e PCs.
hi can anybody help?
I bought this used Xbox controller, and I think it has stick drift. Does anyone know if it could just be a simple software issue, or will I have to replace the whole joystick?
Right joy stick gets stuck rising from 20% to 70% up, then when you use the stick it resets and rises again. I would send a video but I don’t know how.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
It's almost always a hardware issue. You can try recalibrating it in the settings of your xbox or PC.
Then try cleaning it by spraying compressed air into the joysticks. You can also try carefully applying isopropyl alcohol and moving the sticks around, but be sure to let it dry fully before powering it back on.
If these two don't work, it's going to be a faulty joystick.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
live music será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 14
Ao todo: 68
