Ir para o conteúdo principal
Modelo A1297 Unibody: Início de 2009, Meados de 2009, Meados de 2010, Início de 2011 e Final de 2011
How to Install SSD
I want to install a SSD into my MacBook Pro 17. I bought a Mercury Electra 3G SSD. How do I install it into my MacBook Pro? It didn't come with directions, although they told me it would work.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
I just installed a second hard drive in the place of the optical drive in my MacBook the other day! It's pretty nice having the extra capacity.
Even if you just replace your current hard drive with your SSD, you'll see a significant speedup.
Here are the relevant guides:
Replacing the current hard drive:
Substituição do disco rígido do MacBook Pro 17" monobloco
Removing the optical drive:
Substituição da unidade de disco óptico do MacBook Pro 17" monobloco
Go to the last page of this guide on replacing the optical drive (it's for my machine, but the last page would help for installing the second drive)
Instalação de disco rígido duplo no MacBook Core 2 Duo
And finally, the part that iFixit sells for the second hard drive:
[produto vinculado ausente ou desativado: IF107-080]
Good luck and enjoy your SSD!
Imagem de MacBook Pro 17" Unibody Disco rígido
Guia
Nível de dificuldade:
Moderado
15 - 30 minutes
Imagem de MacBook Pro 17" Unibody Unidade de disco óptico
Guia
Moderado
1 - 2 hours
Imagem de MacBook Core 2 Duo Disco Rígido Duplo
Guia
Moderado
1 - 2 hours
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
You either have to: 1.) replace your current HDD with the SSD or 2.) remove the SuperDrive CD burner and replace with your current HDD and put the SSD in the original place that the HDD was in. The latter is the most popular because you can still use the SuperDrive via USB by purchasing external case for the SuperDrive and you just plug and play with the USB, therefore having a HDD and SSD. Also, with the latter, you must purchase an OptiBay expansion kit to be able to place the HDD into the SuperDrive bay.
Pontuação 1
Adicionar a sua resposta
dconkright será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 27
Ao todo: 25,970
