Ir para o conteúdo principal
Apartado dedicado a reparaciones varias que no tengan relacion con electrodomesticos o equipos electricos, mas enfocado a madera, montaje de muebles y reparaciones del hogar
Outdoor faucet issues looking for advice
Imagem
If I did this right you will see a photo of my garden hose. When I took it off in winter time the 2 top pieces are from the faucet. I tried everything wd40, lockjaw pliers I can't get them unfused. Here is the problem though I would like to use my faucet and attach a new hose and I am having trouble finding anything that would fit
Imagem
Hopefully I have a photo of the faucet. I did buy a brass connector but it won't fit. Curious for any advice thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Try screwing the hose back on. If it’s a bayonet type fitting try pulling the second ring toward the hose while pulling the bottom gently away from the tap. (Faucet, I’m in uk)
Esta resposta foi útil?
Pontuação 0
1 comentário:
appreciate the answer it is tight and wedged on there. I sprayed quite a bit of wd 40 on it. I think wd 40 is available in UK
por
Adicionar a sua resposta
Engineer Trainee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Ao todo: 101
