Ir para o conteúdo principal
Controle PS4 modelo CUH-ZCT1. Lançado em novembro de 2013 pela Sony Computer Entertainment, este controlador de seis eixos com bateria de íon de lítio de 3,7 V é simples de reparar. (NOTA: O guia de desmontagem NÃO é para este modelo)
Can this component be replaced?
So when I was trying to change the analog sticks on my controller I accidently knocked off a component fortunately I have a few motherboards with that component can it be replaced?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Yes it can, but requires soldering.
I think it’s a cap.
But since you got the same component on another motherboard, you can just replace it!
Please let us know how that goes!
Esta resposta foi útil?
Pontuação 1
6 comentários:
As long as the pads haven’t been pulled off
por
Do they look pulled off?
por
Hard to see.. can you upload a closer/sharper picture? If the pads are ripped off, you need to repair the solder pad there..
por
@christophe89153 try to apply solder to the contacts; if they stick then you're fine & if they don't then you've ripped the pads off. fortunately it's not such a hard fix judging from the pics but it's a little hard to explain
anyway, try to apply solder to the pads and see if they stick first, that'll help a lot.
por
Update I put solder on the pads and it looks like it's sticking I've uploaded a photo
por
Exibir mais 1 comentário
Adicionar a sua resposta
Christopher D será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 87
