Ir para o conteúdo principal
O Oppo Reno7 5G é um smartphone projetado pela Oppo. O telefone foi lançado em 2022.
Phone not getting charged
I was putting my phone on charging with other charger when I started charging it doesn't start charging it gets off and know it is not open after connecting to it's charger also so what happened to it
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
It's hard to parse your message but I guess you are saying, your phone does not charge? Some things to try:
Test if other devices will charge with your cable and charger. If not:
  • Try a different USB-cable
  • Try a different charger
If that does not help, have good look at the charging port of the phone: does it look dirty or bent?
When you connect your phone to a computer, does it charge? Is it recognized by the computer?
Maybe try rebooting the phone.
Esta resposta foi útil?
Pontuação 0
Well I think your battery is dead and you need to replace your battery with the new battery.
Pontuação 0
Adicionar a sua resposta
Yatharth Kakad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 157
