Ir para o conteúdo principal
Anunciado em 28 de setembro de 2023, o Raspberry Pi 5 atua como uma revisão do hardware do Raspberry 4B.
Change PCIe plastic clip
I broke one side of the plastic clip which keep in place the FFC cable, is there a way to replace just the clip and not the entire PCIe connector? I was able to push the clip back inside and for now seems like it could stay in place and the nvme hat it's working but better safe than sorry
Aggiorna (04/08/26)
Imagem
it’s the circled brown clip
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Can you post a nice sharp image so we can see the connectors details.
por
Yes sorry, I updated the question with a photo
por
Adicionar um comentário
1 resposta
Well from what I've discovered this as an amphenol connector 62674-161120ALF which sadly is no longer made. Instead this might work F31W-1A7H1-11016
Here's the parts schematic of the original to help guide you. Carefully you should be able to tale the new part apart to salvage the latch
62674 Connector. Otherwise you'll need to desolder the connector to replace it with the alternate connector..
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Matteo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 73
Ao todo: 372
