Ir para o conteúdo principal
Informações sobre reparo, desmontagem e resolução de problemas do iPhone 15 Pro Max, o principal smartphone top de linha da Apple, lançado em 22 de setembro de 2023. Ele apresenta uma tela OLED ProMotion de 6,7", um sistema de câmera traseira com uma lente tripla e um novo periscópio de zoom óptico de 5x e 5G. Sucessor do iPhone 14 Pro Max.
Back Glass Replacement - Wireless Charging Coil Transfer?
I’m replacing the back glass on an iPhone 15 Pro Max. I was wondering if the wireless charging coil is something that I am able to transfer from the original? If so, is it just a heat and carefully separate situation? Or is this a component that will require soldering to fully transfer?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The repair required the complete removal of the wireless charging connector and its associated components from the back panel. Following the connector (using heat and an ifixit pick), I slowly peeled the assembly away from the back glass. All in all the assembly includes the camera flash, the wireless charging coil (extremely delicate), and the connector. If it’s removed carefully and installed in the new part, you can avoid any need to run repair assistant and there won’t be the automatic record of the repair in your settings when you complete the process.
Esta resposta foi útil?
Pontuação 0
Did you review the Substituição do vidro traseiro do iPhone 15 Pro Max guide the coil is part of the back glass the replacement will snap into the connector which you can see in Step17 ~ 19
Pontuação 0
1 comentário:
@danj thank you for your reply! Unfortunately, the repair I was performing was from the original unit to an aftermarket back panel. The repair required the complete removal of the wireless charging connector and its associated components from the back panel. Following the connector (using heat and an ifixit pick), I slowly peeled the assembly away from the back glass. All in all the assembly includes the camera flash, the wireless charging coil (extremely delicate), and the connector. If it’s removed carefully and installed in the new part, you can avoid any need to run repair assistant and there won’t be the automatic record of the repair in your settings when you complete the process.
por
Adicionar a sua resposta
Luke Grimes será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 44
Últimos 30 dias: 126
Ao todo: 528
