panic full sensor array 0x200000
Hello everyone, I hope you can help me to find the problem in my ipad air m2 11 wifi, my ipad has just been exposed to liquid, at that time I put my ipad air in a plastic bag, then I didn't realize that water had entered my plastic bag, and the water managed to enter the gaps in my ipad so that my screen background became full of water and restarting started
after that incident I tried to replace the screen and clean the water or corrosion inside my ipad, I looked at the logic board there was no corrosion (but don't know about the condition of the other parts), after I replaced the screen, the case remained the same, namely restarting every 2-3 minutes, and my ipad before turning off to restart, my ipad screen seemed to freeze in place for a few seconds then displayed a pink screen then turned off, does anyone know this problem? this is my full panic, thank you
For example, if the flexible sensor on my iPad Air 6 m2 11 inch WiFi is damaged or torn, can I use a spare part from the iPad Air 5 m1 WiFi to install it on my iPad Air 6 m2 11 WiFi? Is that suitable?
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
