Ir para o conteúdo principal
A versão aprimorada do Nintendo 3DS. Possui telas maiores, maior autonomia da bateria, melhor densidade de pixels e um design mais eficiente.
Weird System Power Issue
My 3DS is having a weird issue. When the 3DS's top screen's hinge is at about a 95-degree angle or less, the system works perfectly. However, if I push the screen farther back, the system fully turns off. I should point out that the system is not modded, meaning it isn't an issue after modding.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
That is weird. If you are OK with it, can you open it up and check the connections on the motherboard?
Esta resposta foi útil?
Pontuação 0
Hi!
I’m afraid it’s related to the top screen..
I would replace it and test if that worked.
Guide: Substituição da tela LCD superior do Nintendo 3DS XL
Note: it’s pretty difficult to perform this repair, so please check with the guide if you want to proceed or not.
Pontuação 0
3 comentários:
Just be careful with the old screen, because if that's not the problem, I think you would want to return the new screen to iFixit for a refund.
por Compartilhar
Even if I replace the upper screen, why do I need a new speaker assembly?
por Compartilhar
What do you mean? I would only replace the topscreen for now.
por Compartilhar
Adicionar a sua resposta
Bobus_Oxen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 145
