Ir para o conteúdo principal
Can I replace or fix the microphone?
The microphone on my M1 Macbook Pro is very muffled.
After some investigation, I'm fairly sure the problem is a blocked grille. But it's hard to identify which (if any) of the hundreds of dimples on the left-hand side are actual holes and therefore need cleaning. Is there any information on this?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Faced with exactly the same problem. I suffered for a long time. In the end, I solved the problem using an old toothbrush and isopropyl alcohol. I soaked the brush in alcohol and massaged the mesh for a few minutes. The computer was turned off. I waited 10 minutes and turned it on. The problem has been resolved
por
Adicionar um comentário
1 resposta
Solução escolhida
I poked around with a pin in the 'holes' on the left hands side, and found some holes that were deeper than the normal divots, about 5 rows in from the right hand side, near the tab and caps lock key. Poking the pin into these fixed the problem.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ben será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 25
Ao todo: 233
