Ir para o conteúdo principal
Guias de reparo, desmontagem e informações de resolução de problemas para a terceira geração do controle DualSense do Sony PlayStation 5. Identificado pelo número de modelo CFI-ZCT1W e placa-mãe modelo BDM-030.
Faceplate Compatibility with other versions
Hi, I own a V3 Controller and it is the Spider-man 2 variant controller. It has developed stick drift and I am hoping to avoid having to solder anything.
Can I transfer the face plate and track pad plate onto a V5 controller?
If not, will the motherboard and sticks from a V5 fit and connect with internals from a V3?
For reference i have the motherboard serial number BDM-030. Any help is appreciated I would love to keep the livery on this controller if joystick replacement is the only option then that'll have to do. Thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Yes that is possible, but you do need the EXACT same model. Also the motherboard must match with each other.
It could be a little difficult, if you buy a incorrect model it just won’t fit as it should be.
Also another option would be to bring to a local repair shop and ask them to solder new hall effect sticks in.
Please let me know how it goes :)
Esta resposta foi útil?
Pontuação 2
2 comentários:
Hi! Apologies for the late response I just attempted it, and it did indeed work. I bought a brand new dual sense and was able to transfer all of the internal components apart from the touchpad which I wanted to retain and the new battery housing. All the internals from a new controller bolt up perfectly. I wanted to reuse the touchpad and faceplate so I did. Due to small changes in architecture I had to also reuse the old battery housing, rear plate and trim piece.
por
No problem at all! Glad that you got it solved :)! Thanks for sharing this with us! Have a great day!
por
Adicionar a sua resposta
Thorne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 111
