Ir para o conteúdo principal
Smart speaker com 8,4 cm de altura, com Siri, fabricado pela Apple Inc. Lançado em 16 de novembro de 2020 nas cores cinza-espacial e branco. Mais tarde, foi atualizado com novas cores, como azul, laranja e amarelo. Número do modelo A2374.
HomePod Touch Sensor Issue Workaround No Replacement Needed
I have multiple HomePods with faulty touch sensors that would randomly trigger playback, which seems to be a fairly common issue based on other reports.
After looking into replacement options, I found that replacement touch panels are difficult to source. Since I rarely use the touch controls and mostly rely on "Hey Siri", I decided to try disconnecting the touch interface instead.
Using a teardown as a reference, I found that disassembly is relatively straightforward and the touch panel connector is accessible without too much difficulty.
I did not document the full process, but if you follow a teardown, the general steps are:
  • The base is held on with strong adhesive, so you will need to carefully pry it off
  • Remove a couple of T6 screws and one T8 screw
  • There are a few additional T6 screws securing the internal assembly
  • Once inside, locate the ribbon cable for the touch panel, which uses a small lever latch connector
  • Disconnect that cable, then reassemble everything
Note:
If replacement touch panels become available, you can replace the touch sensor at this stage instead of disconnecting it, since the connector is already accessible during disassembly.
Result:
You can disconnect the touch panel, reassemble the HomePod, and it will continue to function normally. The only thing that no longer works is the touch input.
I wanted to share this because I had not seen many people suggest simply disconnecting the touch sensor as a workaround. If your HomePod is experiencing ghost touches or random playback, this can be an effective way to keep it usable without replacing parts.
Since most smart speakers are primarily used via voice, losing touch functionality is not a major downside, at least in my case.
Be careful when removing the base adhesive and disconnecting ribbon cables to avoid damage.
Hope this helps others!
Esta é uma boa pergunta?
Pontuação 4
1 comentário
My HomePod mini did this. And if you disconnected it fell into a cycle of 'white light > red light > reset' i.e. there was a phantom press.
However, I found that if you press VERY hard during 'red cycling' then it switches back to the white light, then keep holding down hard and you can get the home pod to enter into 'reset' mode i.e. white flashing which allows you to set it up again.
Once you've adopted it into your home, then in the HomePod settings in the Home App, turn off "Touch and Hold for Siri".
For me, music now plays normally, Hey Siri still works and the volume control works. The only issue is if you have a power cut or you turn Siri off, you have to go through the whole process again. So I've put it in a plug attached to a UPS. This means I haven't needed to disconnect the sensor.
por
Adicionar um comentário
3 respostas
Solução escolhida
Marking as answered since it wasn't really a question and more of a solution.
Esta resposta foi útil?
Pontuação 3
1 comentário:
I’d been having the same problem with one of our HomePod minis for several weeks. As we never use the touch interface and control the minis exclusively by voice, this was the perfect solution to the fault.
por
Hello @notlimahrelyt , thanks for the suggestion, but just to be clear, this is about HomePod 2? If that is true, the only guide I have found is in here, and I can not see the cable you mention:
https://es.ifixit.com/News/71957/the-hom...
THanks in advance!
Pontuação 0
1 comentário:
I have dissasambled my HomePod 2 and contrary to the Mini and old Homepod it will not boot uo without the touch panel connected.
You can disconnect it when the Homepod is running and it isn't bother by it missing then but thats problematic in my other ways.
por
My HomePod mini was stuck in a loop resetting. Followed the teardown instructions and reseated the touch panel, but that failed. I then disconnected it again, powered it on without it connected and THEN connected it. That did - good as new!
Pontuação 0
Adicionar a sua resposta
Tyler Hamilton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 37
Últimos 7 dias: 296
Últimos 30 dias: 1,419
Ao todo: 9,083
