Ir para o conteúdo principal
Lançado em 2 de outubro de 2001, identificado pelo número de modelo DVP-FX810
It won't turn on.
I have checked the battery with multimeters, it's giving me like .1 Volt, which I don't think is very good. Also, the output which I am trying to check, was 1 volt earlier, but is now down back to .006 volts, which I'm not sure is right. Does anyone know what might be causing this? It won't turn on, even with the battery out.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@narenvemury no matter what voltages you have showing right now, you know it's not enough. does not matter if it is 0.1V or .006V The variance i most likely caused by your meter but it's really only academic. You will need to try to charge your battery and see if it will hold a charge or replace it, which is most likely. Your battery sounds like it has been discharged below the threshold of taking a charge..
Now, your device should turn on if you use a 9.5V AC adapter, even with the bad battery. If it does not use troubleshooting flowchart from the Sony DVP FX810 SM.
Imagem
P1 is the power fuse on the main board and D2 is the power diode on the main board as well.
You can download the SM from this page Sony DVP-FX810 under the Documents tab
Esta resposta foi útil?
Pontuação 2
1 comentário:
It's true it has to work without battery!with the battery can try a charge at 19.5 V or even 24 continuous current for a short period of time .The polarity is, with the battery removed and looking at the pins side down towards you, left plus and right minus.There is a high chance that an electron excitation can be made and the voltage 3V.
por
Adicionar a sua resposta
Naren Vemury será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 26
Últimos 30 dias: 48
Ao todo: 218
