Ir para o conteúdo principal
Won't Drain While Running
For the Quiet Partner I, I have the problem that it keeps leaking water. I originally thought it was a bad seal.
After a few troubleshooting sessions I have realized it does not drain while in operation, the bottom fills up till it overflows.
If I push the drain button it will drain. Completely.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi @rbbp8s8kbeq1ops
What is the model number of the dishwasher?
por
@jayeff
Type No: 575-1
MOD: DU1014XTXQ4
Is what I see on the label.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi @rbbp8s8kbeq1ops
Could be a sticking float assembly, a sticking float lever or perhaps a faulty float switch
Here's the tech sheet for the dishwasher.
Enter the Service Diagnostic test mode as described on p.2 (left side) and see if there's a 6 4 (Float switch open) error code being shown when running the tests.
If there is the sheet describes all the possible reasons for this to occur.
If you find the problem and it's due to a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part in the list and note the part number that is shown with it. Search online for the part number only to find suppliers that suit you best.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
B T será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 180
