Ir para o conteúdo principal
Guias de reparo, suporte e informações de resolução de problemas para o primeiro MacBook Air de 13 polegadas a apresentar o SoC M1 baseado em ARM da Apple (com uma CPU de 8 núcleos e até uma GPU de 8 núcleos). Lançado em novembro de 2020 e identificado pelos números de modelo A2337 ou EMC 3598.
Touch ID pairing - Self Service Repair
I am a little confused by the Self-Service Repairs from Apple, and what is and isn't possible.
When I attach a second hand screen (genuine Apple) it gives me the option to finish the repair and it calibrates accordingly.
When I try a second hand Touch ID (genuine Apple) it fails to recognise it as being a genuine part.
My questions are - is it possible to calibrate a Touch ID now through Apple's program? And if so, would I need to buy a new button through the Self-Service Repair from Apple?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
I was going through the self repair program information, and every indication is that the Repair Assistant seems to be able to recalibrate a Touch ID board, at least one purchased from Apple. They don't differentiate that repair from any other one they talk about, so I don't know if there is some restriction on only working on one you bought directly from Apple vs. a used part, but it does specifically mention repairing Touch ID on the M1 MacBook Air.
Mac Laptops Troubleshooting Input/Output Issues - Apple Support
Here's the part they're selling; I assume that's what you're replacing.
Self Service Repair Store
They actually show the repair assistant popping up for a new Touch ID board on their guide to invoking it.
Use Repair Assistant to finish a Mac repair - Apple Support
At this point we're really only guessing; only Apple can authoritatively answer the question of why you can't seem to calibrate a used Touch ID board since they show that process in operation. @flannelist Alisha, do you have any thoughts on this?
Esta resposta foi útil?
Pontuação 1
1 comentário:
Only a new virgin TouchID button and as far as I know only installed by Apple and the data on the drive is lost
por
You are mixing different aspects of Apples Security
Parts Serialization - To kill off knock off parts (not a real issue) - Using the re-serialization (calibration tool) which only works with real Apple parts.
TouchID - Systems data security - The TouchID is married to the its mated logic board and no other!
Pontuação 0
I just tested this, because I found conflicting information. A Macbook Air M4 with Find My disabled. I installed a new logic board from selfservice and left the old TouchID in place. It doesn't work, it won't pair.
Pontuação 0
Adicionar a sua resposta
alasdair Sim será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 75
Ao todo: 321
