Ir para o conteúdo principal
Informações de reparo, desmontagem e resolução de problemas do Steam Deck com tela LCD, um console de jogo portátil fabricado pela Valve, lançado em 25 de fevereiro de 2022. Identificado pelo número de modelo 1010.
Bluetooth and controller not responding
Controls won't respond, and Bluetooth won't connect to anything. Going into desktop mode the controller isn't there, no Bluetooth mouse, no Bluetooth keyboard either.I tried a physical keyboard also and no luck.When I look at controllers connected I get no game controller found, and when I look at the Bluetooth settings it says no Bluetooth adapters found
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
To be honest, I think your Bluetooth chip just stopped working…
Replacing it is probably the best thing to do now.
It won’t be easy as it is soldered on…
Guide: https://youtu.be/uYhc38xFf3w?si=jaaNrBK3...
Please let us know how it goes!
Esta resposta foi útil?
Pontuação 1
2 comentários:
That looks real do-able, the only thing is that the wifi still works. I can connect and go online, no issue there. I'm just wondering why the Bluetooth and controller stopped working at the same time. I have a the same chip already in an unused loaner speaker and I'll put it in tomorrow to see if that's the issue .
por
Hopefully that will be the solution.. the wifi and bluetooth is combined. Please let us know how it goes!
por
Adicionar a sua resposta
David help será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 21
Ao todo: 125
