Ir para o conteúdo principal
Acessório Bluetooth que combina uma ferramenta de captura para o aplicativo "Pokémon GO" e um rastreador de sono para o aplicativo "Pokémon Sleep"
Pokemon Go+ will not power on
My Pokémon Go + will no longer power on or take a charge.I recently had some water spill on it. It didn’t seem like a significant amount, but I’m not sure if that damaged the catcher or if I potentially overcharged it by leaving it on my car phone charger. I’ve tried to replace the battery but had no success. Any idea on what to do next?
Update (03/07/26)
I can check for corrosion but unsure how to examine the motherboard
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Please check the motherboard for corossion. Pretty sure it’s motherboard related…
If there is corossion on it, please clean it completely with isopropyl alcohol.
If possible, can you share some pictures with us?
Thanks!
Esta resposta foi útil?
Pontuação 1
1 comentário:
Is it possible to remove the motherboard and check that side as well. Please clean everything with isopropyl alcohol and also the connectors. Thanks!
por
Adicionar a sua resposta
Jay Sing será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 34
Ao todo: 361
