Ir para o conteúdo principal
Geared for serious gaming and sporting a sleek new style, the TUF Gaming A15 is a feature-packed Windows 10 gaming laptop with the power to propel you to victory.
Laptop does not switch on when charging
When I plug in my charger into my laptop it instantly black screens and when I push the power button it doesn't switch on it still charges tho
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Hi @chris15333
Does the laptop work OK when on battery power only i.e. charger not connected?
por
Adicionar um comentário
1 resposta
If your ASUS TUF A15 black screens when plugged in and won’t power on, try this:
Disconnect the charger.
Hold the power button for 40–60 seconds (EC reset).
Plug the charger back in and try turning it on.
If it still fails, test with another compatible charger to rule out adapter issues. Check the charging port for looseness or debris. If the battery charges but the screen goes black instantly, the motherboard power circuit may be faulty. In that case, visit an authorized ASUS service center.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Chris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 28
Ao todo: 95
