Ir para o conteúdo principal
A a7R II (número do modelo ILCE‑7RM2) é a revisão de 2015 da Sony para a sua câmera mirrorless full-frame de lentes intercambiáveis.
Shutter keeps getting stuck randomly
My camera keeps saying shutter issue randomly and tells me to turn the camera off and on again, sometimes this doesnt even work and I have to remover the battery then it works again until the issue happens all over. Any suggestions?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
There is a mechanical shutter in this camera that can get gummed up. Time to take it to a Sony authorized service center so the shutter can be replaced.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Its not the shutter, its something to do with the Steadyshot I believe
por Compartilhar
@isaiahpimentel - Steadyshot is located within the lens which alters the lens position to offset the small movements within the image. Unless you are getting an error it won't stop the camera from capturing an image.
Try using a tripod so the camera is unable to move does the camera still fail to take a picture?
por Compartilhar
Adicionar a sua resposta
Isaiah Pimentel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 47
Ao todo: 384
