Ir para o conteúdo principal
O Nissan Rogue é um SUV crossover compacto que estreou em outubro de 2007 para o ano de modelo 2008, produzido pela montadora japonesa Nissan.
Clock is in 24hr mode
The clock on my 2017 Rogue is displayed on my dashboard and my radio. The radio clock is in 12hr mode but the dash clock is in 24hr mode. The clock is set through the radio but there is no 12/24hr mode option to do so. Has anyone else had this problem?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
@steve5909 stock radio? with or without navigation system?
por
Stock radio, No navigation. Stock radio has no option for 12/24hr mode
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Here's the owners manual for your Rogue.
2017 Nissan Rogue - Owner's Manual and Maintenance Information - Nissan USA
Page 4-53 has instructions for setting the clock on a system without navigation; see 4-8 for those with it. Here's the relevant information on the non-navigation version.
I've seen some clocks where you select 12/24 hour format by continuing to cycle through the hours setting; if it starts showing numbers over 12, then it's in 24 hour mode, so you would keep changing the hour until you get back to numbers under 12 to switch to 12 hour mode.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Steve será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 20
Ao todo: 130
