Ir para o conteúdo principal
My vibration mode not working
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Check Vibration Settings
  • Go to Settings
  • Tap Sounds and vibration
  • Make sure Vibrate while ringing is turned ON
  • Tap Vibration intensity and increase it
Check Sound Mode
  • Press the Volume Down button
  • Make sure the phone is in Vibrate or Sound mode (not completely muted with vibration off)
Test Vibration Manually
  • Go to Settings > Sounds and vibration > Vibration intensity
  • Adjust the slider and see if the phone vibrates
If there is no vibration at all, continue below.
Restart Your Phone
Sometimes a simple restart fixes minor software issues.
Check Accessibility Settings
  • Go to Settings > Accessibility > Interaction and dexterity
  • Make sure no setting is disabling vibration
Boot in Safe Mode
This checks if any third-party app is causing the problem.
  • Press and hold Power button
  • Tap and hold Power off
  • Select Safe Mode
If vibration works in Safe Mode, an installed app is likely causing the issue.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Not working I think vibration motor not working
por
Adicionar a sua resposta
Deb Mandal será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 29
Ao todo: 159
