Ir para o conteúdo principal
O Acer TravelMate X349 é um notebook empresarial fabricado pela Acer. Esta página contém informações sobre reparo e manutenção relacionados ao Acer TravelMate X349.
How do I fix my mouse pad
So I was using the laptop normally until the mouse pad stopped working so how do I fix it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Hi, @ahmedayman93805 I gotchu.
I found the replacement mousepad here. Ask FixBot to assist you with replacement.
Esta resposta foi útil?
Pontuação 0
Well Check the "Magic" Function Key and also check for driver sometime outdated driver can also be the reason of this issue.
Pontuação 0
If your laptop touchpad suddenly stopped working, start with simple checks. Make sure it isn’t accidentally disabled—many laptops have a function key (Fn + F-key) to toggle the touchpad. Restart your system, as it may be a temporary glitch. Go to Device Manager and check if the touchpad driver is missing or needs updating; reinstall it if necessary. Also check Settings > Touchpad to ensure it’s enabled. Disconnect any external mouse, as some systems disable the touchpad automatically. If none of this works, it could be a loose internal cable or hardware failure, requiring professional repair.
Pontuação 0
Adicionar a sua resposta
ahmed ayman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 146
