Ir para o conteúdo principal
Why is the screen glitched?
Every time i turn it on the screen is covered in fuzzy looking glitches
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Have you tried plugging in an external monitor? That will tell you if it's a memory/GPU issue or a screen problem.
por
Adicionar um comentário
1 resposta
A fuzzy, glitchy screen on startup is usually caused by a hardware or connection issue. Common causes include a loose or damaged display cable (especially in laptops), a failing graphics card, outdated or corrupted display drivers, or a dying screen panel. First, try connecting your device to an external monitor. If the external display looks normal, the issue is likely the screen or its cable. If the glitches appear on both displays, the GPU or drivers may be the problem. You can also try updating graphics drivers or booting into safe mode. Persistent glitches often indicate hardware failure requiring repair.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Smurf_ será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Ao todo: 111
