Ir para o conteúdo principal
O MSI Thin 15 B12V, lançado em janeiro de 2024, é um notebook gamer leve que possui uma tela Full HD de 15,6 polegadas com taxa de atualização de 144 Hz, equipado com um processador Intel® Core™ i7-12650H de 12ª geração e uma GPU para laptop NVIDIA® GeForce RTX™ 4050.
How to fix a cracked screen
I cracked the screen on my laptop and it still works but a small part of it is black
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
If you want to fix this issue, you will need to replace the LCD panel. Here is a replacement part: https://www.newegg.com/lcdbros-msi-thin-...
Ifixit doesn't have a guide for this, but screen replacements are pretty similar across different models/brands of laptops.
You will need to remove the LCD from the screen panel. To do so, gently heat the edges of the screen. Next, run a thin wedge, fingernail, or craft knife along the edge of the screen to pop the clips. You will now have exposed the LCD panel. Remove any screws and clip connectors, and then swap out the old screen. Repete the steps in reverse order. You may need to add a few drops of glue to hold the glass cover in place if the origional clips broke during disassembly.
Let me know if you have any questions!!
Esta resposta foi útil?
Pontuação 0
If your MSI Thin 15 screen is cracked and showing a black area, the LCD panel is physically damaged and must be replaced. Cracks cannot be repaired — only replaced. First, confirm the exact model (check the sticker underneath). Order a compatible 15.6" panel matching resolution (usually 1920x1080) and refresh rate. Buy from trusted sellers like LaptopScreen.com, eBay (high ratings), or MSI parts distributors. Before replacing, power off, unplug, and disconnect the battery. Carefully remove the bezel, unscrew the panel, and swap the display cable. If unsure, take it to a repair shop to avoid damaging the hinges or connector.
Pontuação 0
Adicionar a sua resposta
Mason será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 356
