Ir para o conteúdo principal
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
Pergunta encerrada
Are pentalobe screws still good after removed?
i was replacing the back of my iPhone to make it red, i put the new back in and tried to put back my pentalobe screws but they wouldn't go back, is this supposed to happen, do i need to buy Phillips screws instead??
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Yes, just like any other screw, as long as the correct bit is used to remove it, it will go back in just fine. Did you use a proper pentalobe screwdriver, or something else as a stand-in? Our iPhone liberation kit uses a standard star bit to remove the pentalobe screws, which strips them, which is why we then include Phillips screws to replace them.
Imagem de Compatible with the type 5IPR fasteners used on all models of iPhone since the iPhone 4. Precision fixed blade screwdriver engineered by iFixit.
Produto
P2 Pentalobe Screwdriver iPhone
$5.99
Esta resposta foi útil?
Pontuação 1
1 comentário:
I ordered a new backing, it was sent with two screwdriversmid didnt know which was which and i think i used the wrong one
por
Pergunta mais útil
Check if the new back cover is seated properly. Screw should go back in provided that its head is not damaged when you removed it. Use the correct screw driver to remove screws.
Pontuação 1
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 2,913
