Ir para o conteúdo principal
A terceira revisão do clássico Controle Sem Fio Xbox foi lançada em novembro de 2020, acompanhando o Xbox Series X e Series S. Este controle é compatível com versões anteriores dos consoles Xbox One e PCs.
New TMR Sticks Not Working
I am nee to soldering and know the basics. I replaced both joysticks with new TMR sticks with new Xbox joystick soldering tool. Replacement and soldering went well. But when I go to check controller with Xbox app, it connects but I can't move or use any part of controller. Any thoughts?
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Hi!
Did you tried it here as well > https://hardwaretester.com/gamepad
What is working and what isn't?
por
Nothing works other than the controller turning on and connecting to xbox. I'd post a video if I could
por
Adicionar um comentário
1 resposta
Hi!
Thanks for your comment!
Perhaps traces are damaged or the board went to hot.
Please check if everything is connected as it should and also for damaged traces.
I’m afraid your motherboard did die or isn’t connected properly.
Can you check this? Thanks!
Esta resposta foi útil?
Pontuação 0
2 comentários:
I will have to check for this a little later, but that may be the case. I'm wondering if I may have had too much heat when desoldering the original analog sticks. Thank you
por
That is possible yes... In this case you most likely want to replace the motherboard, but this isn't cheap...
por
Adicionar a sua resposta
kmuetz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 29
Ao todo: 204
