Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2376 Perguntas Visualizar todos
Pergunta encerrada
little ribbon guard mainboard
hi
I just reassembled an new display on my iphone 4 and unfortunately this little black ribbon guard on the top of the mainboard broke off(or is not inserted anymore)
Note that there is a rubber guard on the edge of the logic board where the Digitizer and LCD ribbon cables bend over the logic board. Make certain it is there before replacing the logic board during reassembly.
can anybody tell me, where this piece has to be inserted??or what it is actually for??
thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
The black rubber piece is there to make sure that the ribbon cables for the display do not get creased and instead only bend at a certain degree. There is a little black grove on the rubber piece and that grove fits with the logic board. Its not meant to stay there and can easily come off so all you have to do is slip it back on to the top of the logic board. Here is a picture of it right above where it is put on the logic board:
Hope this Helps
Esta resposta foi útil?
Pontuação 1
ohh this picture ist awesome...thank you very much
Pontuação 0
1 comentário:
If the answer is helpful you can mark it as accepted.
por
its not that important, i dont usually bother to put it back if it falls..
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,673
