Ir para o conteúdo principal
Lançado em 28 de julho de 2017, o New Nintendo 2DS XL é um remodelamento tecnologicamente aprimorado do portátil 2DS. É o nono e último redesenho da linha Nintendo DS. O console é muito maior que o modelo 2DS original e adiciona todos os recursos da linha atualizada de sistemas "New 3DS", menos a capacidade de reproduzir jogos em 3D estereoscópico na tela superior.
Charging light but power button does nothing
Hi
I have a 2ds XL that won't turn on, it charges fine and I have tried a known working battery with no luck, the blue light never comes on, I have checked the 2 fuses and they have continuity, I did check for vaultage on the power button but it doesn't seem to be getting any power when pressed, but it gets continuity, wondering where and how I should test from here
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
You have tested a lot already. Since the battery and fuses are OK, it would be difficult to find where the fault is.
Must be somewhere in the power area near the battery. The power button should work when it gives continuity.
How are the battery pins? Still good? No corrosion?
It could be a lot of things. I think it's easier (I know, it's more expensive..) to get a new motherboard.
Guide: Substituição da placa-mãe do New Nintendo 2DS XL
Esta resposta foi útil?
Pontuação 1
2 comentários:
Well it's more of a want to learn more than a need to fix it lol, guess I just need to learn to follow traces and check where the vaultage stops at this point
por
I would check near the battery, that location!
You can find some more info here: https://gbatemp.net/threads/n2ds-xl-wont...
por
Adicionar a sua resposta
Yelo Hill será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 29
Ao todo: 228
