Ir para o conteúdo principal
The Acer Aspire 5 A515-54 is a budget-friendly, mid-range laptop released in 2019, featuring a 15.6-inch Full HD display, Intel Core i3/i5/i7 processors, and optional NVIDIA GeForce MX-series graphics. Ideal for students and professionals, this lightweight and portable device is known for its sleek design, upgradeable RAM, affordability, and versatile storage options.
My pc isn't turning on after cleaning
Hello, im Benjamin from Chile. This is my situation:
Yesterday i had the curiosity of look inside my laptop, to clean it in case it was dirty, y do not disconnect nothing, i just, quited the case, cleaned the fan, and no much more. but when i closed it and i tried to turn it on, it had no display.
I dont know why, im not an expert in this things, but i have not doing something bad i guess.
This are the signals:
The lateral led lights that indicate the charge works.
Sound a "Pip" when i connect it while it is "turning on"
The screet dont emit any light, its absolutely black
I hope someone in the internet can help me.
i wish you a great day!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@lauriiaviation try this. Connect an external monitor and see if that displays anything. If so, it is possible that you may just have dislodged the monitor connection on your motherboard. You can check that by simply removing the bottom cover and checking it. Also, it may help if you take some well-focused pictures of that you see when you remove the bottom cover from your computer. That way we can see what you see and who knows, we may just find a loose connection etc. :)
Adding images to an existing question - iFixit Repair Guide
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Laurii Aviation será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 58
