Ir para o conteúdo principal
Repair guides for displays (or monitors) for computers or other devices with video output.
nvision monitor Is this broken Lcd fixable?
Monitor LCD
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Adicionar um comentário
1 resposta
Solução escolhida
Hi @nelginrosales
Short answer is no.
The LCD screen is cracked and will need to be replaced as it cannot be repaired.
What is the model number of the Nvision monitor?
Esta resposta foi útil?
Pontuação 0
1 comentário:
Hi @nelginrosales
I can't find a service manual or a parts list for the model so you would have to disassemble the monitor and check if there's a make and model number on a sticker on the back of the LCD panel itself.
Usually LCD panels are made by specialist panel makers to order and not by the manufacturer of the monitor, just so that you're aware of this.
You may also find that if you do happen to find a replacement LCD panel that it may cost as much as 50% of the price of a new better specification monitor.
An option to consider is to advertise the monitor as "Nvision N2455PRO-W cracked screen - good for parts" to try and recoup some of the cost towards a new monitor. Working monitor boards i.e. mainboard, power board etc are always in demand.
por
Adicionar a sua resposta
Nelgin Rosales será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 21
Ao todo: 21
