Screenshot not working anywhere
Esta é uma boa pergunta?
It looks like you're browsing through iFixit for some troubleshooting! Here are some helpful ways to respond to Jack Ponder (Whirlpool washer) and Pankaj (Oppo A17).
Jack mentions his older analog washer requires a "bump" to continue the cycle. This usually indicates a mechanical failure in the timer assembly.
Pankaj is unable to take screenshots on an Oppo A17 (model CPH2477). This is often a software setting or a hardware button issue.
Would you like me to help you draft the exact text to post for either of these users?
Esta resposta foi útil?
@khushiupadhyay you need to at least delete this "Would you like me to help you draft the exact text to post for either of these users?" when you are using AI. Let me quote my colleague @dadibrokeit
Readers are cautioned to take this advice with a large grain of salt. All indications are that it is AI-generated and as such has no common sense. You should also not assume the person posting this has any knowledge of the subject at all, given that they are not the author of this post; an AI database produced it, so it is useless to ask for further information or clarification.
A word of caution. We do not mind if you use AI but you will have to be transparent about using it. You need to inform the community that your answers are generated/augmented by AI.
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 46
Ao todo: 185
