Charger cable pops out
Charger cable easily pops out. Have tried to clean the usb-c Connector.
Esta é uma boa pergunta?
"First, use a bright light and a magnifying glass to inspect the charging port clearly. Look for any compressed lint or debris stuck deep inside that might be preventing the cable from clicking into place. If there's anything inside, carefully clean it out with a thin non-conductive tool. However, if the internal pins are bent or misaligned, you will need to replace the entire charging port assembly."
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 24
Ao todo: 136
