Ir para o conteúdo principal
Cutsor is not showing
Cursor is not working
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The issue with the cursor (mouse pointer) not showing on your Lenovo XiaoXin Air 14 Plus (also known as Xiaoxin Air 14 Plus) is a common problem on Lenovo laptops, often related to the touchpad being disabled, driver glitches, or temporary software hiccups.
Try some quick checks:
  • Plug in an external USB mouse—if the cursor appears and works with it, the issue is definitely touchpad-related (not a display/graphics problem).
  • Disable "Hide pointer while typing" in Control Panel → Mouse → Pointer Options tab (uncheck the box).
  • Perform a power reset: Shut down completely, unplug the charger, hold the power button for 30–60 seconds, then plug back in and turn on.
  • Run Lenovo Vantage app (pre-installed on most Xiaoxin models): Go to System Update and install any pending updates, especially for hardware/drivers.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Avika Shrivastav será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 19
Ao todo: 139
